So everything works fine... for about 25 seconds then the tuner toggles off by itself and toggles my IA mode switch between IA or preset to the opposite setting from where it was. I'm lost....
I've tried it here and don't see the same problem. Maybe your IA Mode switch is going bad? Try disabling the IA Mode button (set Type to None) and see if the problem still happens. If it goes away, there's probably an issue with the button.
