Best Practices Using PBC Mixer on 6-10 Loops
Discussion in 'PBC General Discussion' started by sjgam, Jun 10, 2019.
  1. sjgam
    sjgam
    Mar 25, 2018
    39
    3
    New to the PBC and have modulation pedals on loop 7,8 & 9 (chorus, phaser & flanger) and delay on loop 10.
    My observation with PBC mixer is that in general parallel allows more of the original signal to come through and in series effect is thicker.
    So for lead tones that have a mod and/or delay I use parallel so source tone comes through and for pure mod chain, I use series to make it thick as intended.
    My delay is a Chase Bliss Tonal Recall RKM and has Mix dial and midi controllable presets so I can use Series and lower mix by preset and keep it in series if I want.
    None of my mod pedals have mix or preset ability so I use the parallel and series at PBC preset level for them.
    What are you guys doing with the mixer on PBC for series and parallel?
    #1 sjgam, Jun 10, 2019
  2. JimGtr
    JimGtr
    Dec 29, 2017
    26
    14
    I do my modulation in series to get the full effect, and delay and reverb I do in parallel (with kill dry enabled on those effects).
  3. shoelesscraig
    shoelesscraig
    May 30, 2017
    239
    28
    This is EXACTLY what I do as well. Mobius in loop 8 in series, Timeline and BigSky in 9 & 10 in parallel.
  4. trulsux
    trulsux
    Sep 2, 2011
    52
    5
    ....do you mute the dry signal in the PBC??
  5. JimGtr
    JimGtr
    Dec 29, 2017
    26
    14
    Opposite. I mute the dry on the effect units I'm running in parallel (reverb and delay). So the dry signal you're hearing is has never passed through the effect units.
Share This Page
