[DONE] Device list add? CBA Mood Mk2
Piplodocus
Kinda mentioned it in another thread, but thought I'd put it in a separate post so it doesn't get missed...
If updating SW could you check if it does Mood Mk2 features? From memory it had Mood (Mk1) but I think Mk2 adds CCs for many of the DIP switches and other newer functions.
Reason I'm not definitely sure is I down't own it yet. But highly likely to get it in the next few months, so figured getting the request in now means I won't have to wait a few months if I request it later. So not nearly as fussed as it being added currently as some of the others request I already use, but figured it might be easier to add all at once sooner rather than later if you're doing the others anyway.
Cheers! :)
If you hang on I can tell you which are missing. If you update would be quite nice to rename a couple slightly too to make it more obvious which they are.
Missing...
1​
Synth Mod Wheel
57​
Synth Transpose
58​
Synth Output Mode
59​
Exit Synth Mode
61​
Ramp Wet Time
62​
Ramp Wet Modify
63​
Ramp Clock
64​
Ramp Loop Modify
65​
Ramp Loop Length
66​
Ramp Bounce
67​
Sweep Direction
68​
Polarity
71​
Classic Mode
72​
MISO
73​
Spread
74​
Dry Kill
75​
Wet Trails
76​
Latch
77​
No Dub
78​
Smooth Clock
80​
Synth Attack
81​
Synth Decay
82​
Synth Sustain
83​
Synth Release
84​
Synth Portamento
107​
Tap Tempo
Those names should hopefully be nice and clear. If it's not too much bother and you're changing it I don't suppose you could do me a favour and also rename some already there to make their function clearer please:
CCCurrent NameSuggested new name
14​
TimeWet Time
16​
LengthLoop Length
17​
Modify 1Wet Modify
19​
Modify 2Loop Modify
21​
Wet ChannelWet Channel Mode
23​
Micro looperMicro Looper Mode
105​
FreezeWet Freeze
106​
OverdubLoop Overdub
Thanks Ron :)
