External Switch to change Song and Preset
Okey
Hi everyone,
I've a RJM-SP1 connected to my GT16 that I mostly use as a wah in combination with my Mobius.
For some parts of my set I need to jump directly into the next song for some sort of medley.
Can I set up the external switch to jump to a different preset (in another song) and activate that song simultaneously? Until now I only managed the switch to activate a preset of the song I'm in or to use it as a bank up/down, which forces me to do one additional step on the wanted preset.
Thanks for your help!
Would overriding the Ext Switch action in the preset menu, then adding necessary IA actions for that particular switch to change to the song/preset you need to go to, work?
If you're using different presets in each song, then using a System / Preset action should load up the desired preset and the song it belongs to (assuming you're running recent firmware).
