H&K Grandmeister 40 midi
Discussion in 'LT General Discussion' started by RainWizerd, Oct 28, 2018.
  1. RainWizerd
    RainWizerd
    Oct 24, 2018
    6
    0
    I'm using the IA page to recall the 4 amp channels on my amp. CC messages and it almost works like I want. I'm using the IA as a stompbox mode. Amp channel changing only. I run into a problem with changing the channels. It mis reads when going out of order.1-clean 2-crunch 3-lead 4-ultra. When going from 1, 2, 3, 4 it changes the channels fine. I'm sending cc message 31 for amp channel and different values to recall a certain channel. When I go from 4 to any other channel it defaults back to 1(clean). I hope I explained this well.
  2. RainWizerd
    RainWizerd
    Oct 24, 2018
    6
    0
    Note: I have to hit a button twice to call up that channel after it goes to clean.
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    5,125
    866
    You will need to set the buttons to the same group number, and in global settings, turn off Send Off Messages for that group. (This has to be done in the editor software).
  4. RainWizerd
    RainWizerd
    Oct 24, 2018
    6
    0
    That was the fix. I had them in G1 already but the send off did it. Thanks.
  5. overdrive59
    overdrive59
    Jul 28, 2017
    24
    0
    I have used the LT with. Grandmeister as well. I used an IA cycle to quickly rotate between channels. Save me from using a separate button for each channel.
Share This Page
