Michael Gergen
I'm controlling a couple pedals with the LT including an HX Stomp. I've assigned MIDI channel and CCs to blocks in both pedals. Other pedals are set to pass MIDI thu. However, when I send a CC to bypass a block the block flashes on and then off immediately. I am new to the LT but think I've got everything set up right. Don't know if it's a setting I need to switch. I tried a momentary CC and toggle CC action in the preset. I assigned an IA to each of the blocks I'm trying to control and that works as expected which is why I came here for help otherwise I expecated an issue with the Stomp. I set the Stomp up as a Generic CC/PC Device, wondering if I should try the Helix preset in the Devices dropdown. Any help would be apprecaited. Thanks!
