Hi......My setup is a Diezel midi amp and various midi pedals. The amp does not respond to specific Midi program #s or CC - it has a learn mode where amp remembers which channel is for each Mastermind preset. My approach to setting up the LT is basically centered around that limitation. I need to go to a different LT preset if I want to change channels on the amp. There are times I play around with effects and want the same sound I am using but only want to change the amp channel (maybe from clean to gain for example). I probably can just simply create another LT preset and store the amp channel I want and choose to not send midi messages to everything else so they remain in the same state. My thought however since I don't want to have to go to different banks (and LT has limited # of buttons) was to create the new presets in a distant bank but then create a hold button for my current presets. The hold would then be mapped to 1 of those new presets. So for example, Preset 1 is clean channel (and turns off all effects); Preset 2 (Dirty Channel and turns off all effects); all the way through 4. If I can program each of those as a hold, when I hold it down it can switch to the new preset where it changes to the amp channel I want but leaves effects as is (if I have delay and reverb on, it will stay on).
Any idea if this can be done?
