Mesa Mark V 90watt & Eventide Eclipse Control
Hello,
Currently own a Mini Amp Gizmo to handle channel switching on my Mesa MkV. However, recently I've decided to go with a rack system as opposed to lugging around my 34 inch, heavy pedalboard. My rack system is simple; Two Notes Torpedo Live & an Eventide Eclipse. I want to control all my switching with a Mastermind LT. Just because I like the idea of using minimal real estate and making things less complicated.
So, I have the amp gizmo and the required cable for handling the amp switching. My question is, do I need to continue to use the amp gizmo to do channel switching and just run a midi cable from the LT to the Amp gizmo? Or, can the LT handle the channel switching without the amp gizmo and required cable?
Thank you for your input \m/
You'll still need the Amp Gizmo to do the job, the LT doesn't have enough switching capacity by itself.
So I'll be going from the LT to the amp gizmo > mkv > eventide eclipse?
Correct?
Actually, in order to use the LT powering capabilities is should be going LT > Eclipse in > Eclipse out > amp gizmo > MkV.
Better scenario?
For optimal power setup, the Amp Gizmo should be the one connected directly to the LT.
