Mini Amp Gizmo and cable for Mesa RK II pinout
Discussion in 'Amp Interface Cables' started by Stefan K, Sep 4, 2017.
  1. Stefan K
    Stefan K
    Sep 1, 2017
    4
    0
    I bought the Mini Amp Gizmo with the interface cable for Mesa Road King II. Now I want to modify the cable, so that I can switch the mute instead of the reverb. The reverb is switched on all the time in my setup.
    Please can you send me the pinout of the Mesa® RRN (Rectifier®/Road King™/Nomad) cable? And as well the instruction sheet?
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    5,350
    929
    The instruction sheet is attached.
    To get access to the mute, you'll need to replace the connector on the amp end with an 8-pin DIN. Mute is on pin 8. Move the blue wire from pin 7 (which is reverb) to pin 8.
  3. Stefan K
    Stefan K
    Sep 1, 2017
    4
    0
    Thank you very much, this helps a lot!
    Just a question, for the sake of completeness, can I get the rest of the pinout?
  4. rjmmusic
    Staff Member
    Jan 18, 2010
    5,350
    929
    The connector pins on the Road King / Roadster are as follows:
    1: Ground
    2: +5 volts
    3: Channel select (different voltages on this pin select different channels)
    4: Loop (Loop 1 on RK)
    5: Solo
    6: Loop 2 (RK) or Mute (Roadster)
    7: Reverb
    8: Mute (RKII) or Ext Switch (RKI)
    Stefan K likes this.
  5. Stefan K
    Stefan K
    Sep 1, 2017
    4
    0
    Thank you very much, now I can start modifying...
  6. Stefan K
    Stefan K
    Sep 1, 2017
    4
    0
    Hello again, ...
    Where can I find the pinout for Mini Amp Gizmo interface cable for:
    Mesa Mark V
    and
    Mesa Dual Rectifier 3 Channel Multiwatt?
    Thanks for your help!
    Best Regards
    Stefan
Share This Page
