lbcbdr
Finally got the new pedalboard together. Layout is as follows Line6 Relay G50 wireless into PBC. Loop1 EHX C9, Loop2 Strymon Mobius, Loop3 Keeley c4 compressor, Loop 4 EHX Soul Food, Loop 5 Walrus Jupiter FUzz, Loop6 ProCo Turbo Rat, Loop7 Way Huge Fat Sandwitch, Loop8 Strymon Timeline, Loop9 TC Hall of Fame mini, Loop10 TC Ditto2. Volume pedal is inserted between loops 6-7. Output A goes to normal channel on Vox AC15HW1x, Out B to the TOp Boost Channel. Fn switch 1 goes to the hot cold switch on the Vox. Roland EV-5 is plugged into the PBC and controls the Mobius or Timeline depending on the preset.
On the rear there is a patch between the G50 out and the PBC in to facilitate plugging in a cable instead of the wireless. The other 3 patch points are the hot cold switch out and out a and b of the PBC.
The board is a pedaltrain classic pro and the rear plate is a standard 2 space rack blank. I used Neutrik PowerCON for the power connection the grey connector is power out in case I need more outlets at the pedalboard. All pedals are powered by a voodoo labs 2+ and Digital power supplies mounted underneath. There is a TC Polytune mini plugged into the wireless aux/tuner out as well.
LBC
