Mikeohman
I have 2 amps - Kingley Regent with FX loop send level control, and a Bad Cat Cub15R with no send level control.
The Kingsley works perfectly, the Bad Cat overloads / distorts the line mixer in the PBC as far as I can tell.
It distorts with all loops in bypass so I assume therefore it is the line mixer that is distorting.
I inserted a volume pedal between the Bad Cat send and the input to the PBC, turned down the leve a bit and that solved the problem.
However - having to use a guitar volume pedal just for this purpose is inconvenient to say the least.
Any suggestions other than installing a level control in the Bad Cat amp?
