Signal Chain Using Rjm Mini Line Mixer
muzaniazman
Hello
I would love to buy the Rjm Mini Line Mixer and put it on my pedalboard. So could you please suggest me the signal chain as I want my pedalboard to run as wet/dry system. Here are currently pedals I'm using:
1)A custom buffer box which is ceriatone Klein-ulator(send/return loop & output & input)
2)Moen gec8jr effects looper switcher
3)2 Hardwire DL-8 Delay
4)Strymon Blue Sky
5)Tc Electronic Chorona Chorus
6)Isp Decimetor Noise Reduction
7)Tonebone Hot British
8)Xotic Ep Booster
9)Jim Dunlop Joe Bonamassa Signature Cry Baby
10)Boss FVL500 Volume Pedal
I'm also running all my effects in 2 Ceriatone amp which is AFD 100 watts & Pexi 2550 50watts(modded amp by Mr. Nik Shazwan Azam from Malaysia)
Thank you
Firstly, I connect the amps loop send to the klein Input. Then I connect the klein out to the looper switcher input and lastly I connect the looper switcher output to the klein Return. I'm guessing there will be other configuration if I'm gonna put the mini line mixer? As I'm concerned, the mini mix will act as a splitter for the two amps. The klein-ulator doesn't do any split for my setup. My mistake from previous post, It's actually I want to run my setup to two amps with wet/dry rig.
