Song/Bank Name Change Speed
Stewart
Hi guys
When banking up or down to through songs in a setlist, the LT display takes a second to change - the current and next song titles kind of merge into one another.
Is there a way to make the bank name appear instantly/faster when scrolling? Wasn't sure if bank time would effect this or just the presets within the bank.
Thanks
Are you using a Kemper? The Auto Names feature waits for the performance name to come back from the Kemper, so there's a little delay there. Tuning off Auto Names is the only way to fix that. Otherwise, any other delay would be related to the time the LCD takes to update, and there isn't really anything we can do about that...
Yes - using a Kemper, but not using any of the Kemper performance or slot names, only using the song and preset names from the RJM editor.
Thanks anyway, much appreciated!
Have also found an odd glitch in the LT - hoping you can help.
When scrolling through banks/songs, it's started adding an extra button push on certain banks before loading the next.
For example:
Preset 1>(press bank up)>Preset 2>(press bank up)>Preset 3>(press bank up)>Preset button light goes out, but preset doesn't change>(press bank up again)>Preset 4
Have looked through the editor file and can't see anything that would cause this?
Not a major issue but obviously quite frustrating when you're going from one bank to the next!
  • Kev RJM 23-03-19.rjs
The Song Fossils has no presets assigned to it, that's what's causing the problem. Once you assign one or more presets, it will start showing up as you bank up.
