Tuner Display from Kemper
Andy Gergen
Hello!
Im setting up my LT with the assumption that it supported the Kemper's tuner on the LT's display like the GT but Im having trouble and wondering if it is actually supported on the LT.
If it is, what could I be doing wrong?
Latest LT firmware and lates Kemper (non-beta) firmware.
Everything else seems to be working correctly between the Kemper and the LT.
Ok, I figured how to get it working with a button but Id prefer it if It engaged the tuner when the volume pedal is at 0.
Ok, do the following:
On the LT itself, go into setup and select Expression Pedal. Move the pedal to just a hair above 0, then select Set Position Switch in the menu.
Now, read the settings into the editor. Edit the expression pedal (ExpPdl1 in the Globals tab). In the bottom section, click New Action. Set Action Type to System and Subtype to Tuner. Click Add CC Action. Select Profiler / Tuner and click Done. Check the Invert Position Switch checkbox.
Now, when the pedal goes below the position you set, it will turn on the LT's tuner display and send a message to the Kemper to enable the tuner.
