Re: Making your own cables...
While I've used the Planet Waves solderless cables (they're easy to repair on the fly WHEN they fail), and some people (like Eric Johnson) seem to like the George L's stuff, there's no doubt in my mind that properly soldered cables last longer, are less prone to intermittent problems, and sound better.
Soldering ¼" jack cables is EASY. There's plenty of room to work with (smaller connectors are trickier - XLRs aren't too bad, but 3.5mm minijacks are fiddly and DIN connectors are a nightmare), they're easy to assemble, and once you get the hang of it you can rattle them off in no time. I can cut, solder and assemble a new patch lead in 5 minutes easily... and by buying cable and connectors in bulk, you'll be saving a fortune. Particularly compared with so-called "premium" brands like Monster, who I wouldn't touch with a bargepole, as they're notoriously unreliable (that's why they NEED the lifetime warranty
