rjmmusic
 Re: Suggestions, please!
Thanks, Vance! That describes the situation exactly. We can only work with these effects processors as much as their MIDI implementation allows. And, if the manufacturers don't want to divulge any information, we'd have to reverse engineer. I have to look into the legality of reverse engineering as well - don't want to open up a can of worms...  All I can say for sure is that we're going to build in as much support as we can!
| Thu Mar 03, 2011 2:25 pm |
Cpt Flake
Hi
I have few questions: 1. What is the aproximative date to put it on the marcket ?? When do I will able yo buy it ?? 2.My plan is to past my futur MM GT in a RG-16 for control an Axe-FX and a Mesa Boogie Mark V. Do I will able to do that ?? 3. If I creat a patch in my axe-fx, does the RG-16 select this patch or ,for example, the button one(on the RG-16) is for delay, two is for reverb... ???
_________________ I will keep my dream until the end !!!
| Thu Mar 03, 2011 9:44 pm |
rjmmusic
We're not sure on a date yet, but are estimating Fall 2011.
It'll definitely be able to control an RG-16 and an Axe-Fx. The RG-16 won't control the Axe-Fx (except to switch it out of your audio path), but the buttons on the MMGT will be able to control individual effects on the Axe-Fx.
| Fri Mar 04, 2011 10:55 am |
Cpt Flake
Ok, thanks !!!!
If the Rg-16 won't control the Axe-Fx, but the MMGT can control it, can I control the RG-16(for my amp) and the Axe-Fx with the MMGT in the same time ??? If don't what do you suggest me if I want to use the patch of the AxeFx in my preset(example: amp: chanel 3 with patch 10 on axe-fx: delay, reverbs and comp.) and I want to be able to press the button and have this efect. I'm explain: in ''preset mode'' I want to use patch on my axe-FX (ex: chanel 3(amp) with patch 10(axe-fx) but in ''free'' mode (no preset just press the button I want) control all effect individually. I want preset 1,2,3,4,5...(for show) and I want button for amp chanel and effect individualy. What do tou suggest me for that ??
Last question: do you have an aproximate price ?? thanks a lot !!!!
| Sat Mar 05, 2011 10:30 am |
MartinCliffe
Joined: Tue Feb 02, 2010 11:47 am Posts: 348 Location: Staffordshire Moorlands, UK
Yes, you can control up to 16 devices at the same time.
_________________ A Viking in Hong Kong
| Sat Mar 05, 2011 12:45 pm |
rcknrllmn
Hello, I think this is a great controller you are developing. Will this unit be able to send "note on" messages to samplers, Keys, and etc? I currently use a Roland FC-300 for this. I just wish it had more controller switches, to start songs, control my presets & instant controller switches.
Cheers.
| Fri Mar 11, 2011 8:37 am |
rjmmusic
Yes, it'll send note on/off, transport control, sysex - we're trying to make it as versatile as possible.
| Fri Mar 11, 2011 5:10 pm |
Cpt Flake
But there is just one Midi out on the MMGT, how can I control the axe-fx and the RG-16 with only one midi out ??
| Sun Mar 13, 2011 7:30 pm |
MartinCliffe
MIDI is a serial connection - you can daisy-chain devices using the MIDI Thru port. So device 1 MIDI out > device 2 MIDI in // device 2 MIDI thru > device 3 MIDI in // device 3 MIDI thru > device 4 MIDI in etc. In practice, you probably don't want to connect more than 4 or 5 devices together like this, because every extra device increases the risk of data loss, which is why MIDI Thru boxes such as those made by MIDI Solutions exist (and work very well indeed!)
Also, technically the MMGT has two MIDI outs - there's the standard 5-pin DIN connector, and there's also a MIDI over XLR connector. I assume (I'd have to check with Ron to be sure) that you could run them in parallel, to connect to more devices without data loss.
| Sun Mar 13, 2011 11:31 pm |
Cpt Flake
Very cool, thanks !!!!
| Mon Mar 14, 2011 3:03 am |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
