View unanswered posts | View active topics It is currently Wed Jun 19, 2013 6:23 pm
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
Switching amps AND channels with a midi controller ?
Post Re: Switching amps AND channels with a midi controller ?
Wow the RG16 is an amazing solution! Its exactly what I need.
Last questions :
1. With that setup is there any ground problem or something? I don't know anything about electricity.
2. This "patch cable"... is it a standard 1/4" jack? Or is it some kind of special cable that comes with the RG ? (sorry if this is a stupid question).
Thank you very much 4x4uk I appreciate you taking the time!
Sat Jul 23, 2011 12:06 pm
the ground loop issue may or may not occur, but when connecting 2 amps it may do. THere is a good guideline thread from Ron on here somewhere re using making groundlift cables. But basically a ground lift cable is a std 1/4 inch jack cable witht he outer shield removed from one end. It is likely you may need one but you never know until you connect everything up.
The patch cable is a std 1/4 inch jack cable its just short in length
Boss GT Pro,TW1,CS3,DF2,HF2,DD2,DR-3, Ibanez SD9,PT9,BC9, Behringer DS20424P,MX882,RX1202FX, EHX 2880
Marshall MGP 9001 & 8008, Nitrotube,S/amp PSA1.1, Carlsbro Stingray, FC300, RJM RG16, Effect Gizmo, MidiSolutions Event Processor & Quadrathru
Sat Jul 23, 2011 12:26 pm
just remembered there is a ground lift switch on the rg16 so you may not need a groundlift cable
Sat Jul 23, 2011 12:30 pm
Okay yeah thanks!
And finally, if ever I need one, it is really just ONE groundlift cable? which one?
Sat Jul 23, 2011 12:32 pm
Oh sorry, I just found the blog post you're talking about, I understand!
Thank you!!
Sat Jul 23, 2011 12:35 pm
no problem you welcome, thats what I was looking for couldn't remember where it was
Sat Jul 23, 2011 12:36 pm
Localized by Maël Soucaze © 2010 phpBB.fr
