Page 1 of 1
[ 5 posts ] |
phantom power for Mastermind question
7slinger
hi, don't know which forum (gizmo or mastermind) this is more appropriate for, so I'll try here.
I have a mini amp gizmo that is phantom powering a mastermind. what I want to do is hardwire my mastermind midi cable to my pedalboard, hardwire the mini gizmo cable to a midi panel jack on my rack, and then have 1 midi cable to connect between the side of my pedal board and the front of my rack for gigs.
I've never done this, so my question is first off is this possible? I've looked around and 7 pin panel jacks are available...if wired correctly will they pass along the phantom power?
hope this question makes sense, and that somebody has good answers for me; I'd hate to buy all the stuff only to find out it never had a chance of working.
thanks,
Patrick
| Mon Aug 23, 2010 8:03 am |
rjmmusic
 Re: phantom power for Mastermind question
If you wire 7-pin connectors straight through, it'll pass phantom power, no problem.
| Tue Aug 24, 2010 8:19 am |
7slinger
thanks so much, that's great news
so to continue with the noob questions, if I'm wiring jack to jack, as long as pin1 is wired to pin1 and so on and so forth, everything should work correctly?
thanks again
edit: also, I've seen before where people have wired midi into XLR connectors, and are able to achieve locking jacks this way...possible or no with this setup? do I need to know what lead numbers are doing what? sorry kinda rambling it's early and not much sleep
| Tue Aug 24, 2010 5:52 pm |
rjmmusic
Yes, pin 1 to pin 1, etc. As long as you keep consistent, it'll work. Same goes for XLR connectors - as long as you make sure that each pin on the Mastermind side ends up getting connected to the same pin on the Gizmo, you can use any kind of connector you'd like in between.
| Wed Aug 25, 2010 10:42 pm |
7slinger
so, I wired up my board and rack with locking 7 pin xlr jacks and everything works great! makes for a very tidy setup. thanks for your help, and thanks for great products
| Tue Jun 14, 2011 2:39 pm |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 1 guest |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
