Page 1 of 1
[ 5 posts ] |
Mini line mixer - how to adjust the FX mix ?
| Author |
Message |
Antoine
Hi
Antoine from Belgium, I'm new here. I wondered if there's a possibility to adjust the mix % on the mixer ? Or is it set to a fix value ? let's say 50 % for example ?
Antoine
| Thu Nov 10, 2011 5:24 am |
MartinCliffe
Joined: Tue Feb 02, 2010 11:47 am Posts: 349 Location: Staffordshire Moorlands, UK
 Re: Mini line mixer - how to adjust the FX mix ?
It's a straight mixer... it mixes equally whatever levels you put into it. To adjust your FX level, adjust the output level of your effects device.
_________________ A Viking in Hong Kong
| Thu Nov 10, 2011 9:55 am |
Antoine
Thanks for the info. in context, is it easy to work with it that way ?? I guess that once you set the level from the FX, you never change them ?
I'd be using a Strymon Timeline , Strymon Bluesky Reverb and Eventide Modfactor in it
| Thu Nov 10, 2011 3:14 pm |
MartinCliffe
It's certainly nothing I've ever had an issue with. I use the volume control on the Mini Line Mixer as the overall master volume for my rig... I set the levels in my FX on a preset-by-preset basis to get relative levels, then when I'm at the venue I adjust the overall FX level using the output volume on the processors to suit the ambience of the room - some rooms I find I need more effects than others.
| Thu Nov 10, 2011 11:09 pm |
Antoine
THanks man !
| Fri Nov 11, 2011 12:45 pm |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 0 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
