Re: Home made simple Cable
For the info of any other Carvin owners with a TRS jack to switch channels & Reverb (X100B, Legacy, MTS, Nomad, Belair) I have now done this & it works a treat!
I wired the tip of a TRS plug plugged into the FS22 Jack on my Carvin amp to pin 8 on an 8 pin Din plug & the ring to pin 2 & sleeve to the Din plug shield.
I had to change switch 2 on the Amp Gizmo to Invert mode but it now switches fine & I can use the same patches on my G system as I use with my Mark V.
Switch 8 also needs to be in invert mode but it is already set this way for the Mark V so I did not need to change this.
Also Switch 1&2 must be grouped but I already have 1-3 grouped for my Mark V anyway.
