1st posting and here is my main-setup
joe web
hi folks,
i´m new to this board, but i´m using the RG-16 since two years now and i´m still happy with this great unit.
it allows me a lot of switching and looping action all in one unit - that´s great!
thanks again Ron, for making this "custom" switching-cable for my Dual Rectifier!
here is my setup and how it´s wired up - enjoy.
main rig:
the floorboard:
and this is, how it´s hooked up:
in this setup, i can switch between the two preamp-sections of the amps.
since two weeks i´m trying a different wiring, to be able to switch between both preamps and / or use them in parallel....
i´ll update the picture as soon as i´m sure that everything works fine.
Sweet looking rig - we have similar ideas, it seems, switching two preamp-sections then using the power amp sections for stereo. Is the little 1/2 rack Boss unit used for the piezo output? Is that someone else who has a mic stand mounted on their pedalboard? :)
your are right, but it´s not a boss unit. it´s an old yamaha fx550, i use light compression and a bit of reverb for the piezo signal.
the mic-stand is mounted to the pedalboard - yes. i´ve seen this at the paul lenders homepage. he build a pedalboard with an integrated mic-stand and i thought "yes, that´s it!". never ever any trouble with the stupide stands on stage.
as always, you put everything on stage and make it ready to go...then there is this mic-stand left over...hm, where should i put this thing now? ....this is over now. :)
I hear that... with mine, I took it one stage further and mounted my monitors on it as well:
Now if only there was also room for a fan and a couple of PAR56 LED spotlights, I'd not have to have any excess junk on the floor :)
