IggySniff
Hey, I am having a problem with 2 way communication between my MMGT16 and my new FX8. I can control the FX8 no problem, changing presets and scenes works, but the tuner function on the MMGT isn't working (i get a "?") and when I switch presets it doesn't update which effect blocks are active, so it seems like the FX8 isn't talking back to the MMGT.
My current midi path is as follows:
MMGT16 phantom powered through 7pin midi cable to Effect Gizmo on my rack, then through a Mini Amp Gizmo, a few other midi pedals and ending on the FX8. From the FX8 midi out I have a 5pin midi cable going to the remote in on the MMGT16. Bidirectional midi is off on the MMGT and midi thru is turned off on the FX8.
I have tried 3 different midi cables and no luck, I checked the cables and all 5 pins are connected. I then tried connecting the MMGT16 directly to the FX8 with a single 5pin cable (turning on bidirectional midi on the MMGT16) still no luck.
I tried following a few guides I have found for setting up an Axe Fx with MMGT, but the FX8 obviously doesn't have all the same options. Any ideas?
