First, sorry for another problem post. I am just going through reworking a couple of rigs to make them a bit more efficient by incorporating an Axe-FX III as the effects unit with the amps. So far everything has been great and the two phantom power box I ordered really help make everything much more elegant. Now, to the new issue.
In order to use the MMLT as a midi interface with the Strymon Timeline, I have to connect both Midi in and out on the pedal to the in and out on the Strymon. With this basic connection, Nixie connects flawlessly to the Timeline through the MMLT. Of course, to use all the features of the Axe-Fx III, I also need to connect its midi out to the midi in on the MMLT. I bought a Midi Solutions Merger to merge the outputs of the Timeline and Axe-Fx III and connect a single cable to MMLT midi in. This worked flawlessly as well, but requires running two midi cables to the rig and MMLT. I bought a Phantom box to cut the cabling down to one (yes, one cable makes a difference). Connected the midi out from the merger box to the Phantom power box and the midi in on the Axe-Fx III to the Phantom box, and one 7-pin cable to the MMLT. Axe-Fx III works beautifully.
Here is the problem. The Nixie software now cannot connect to the Timeline. It acts as if the circuit is not complete since it says it cannot find a Strymon device. However, if I connect a 5-pin midi cable to the second output on the merger box and connect the cable to the Midi In on the MMLT, Nixie recognizes the Timeline and all is good. The problem seems to be that Nixie cannot communicate with Timeline through the 7-pin cable. Is this true?
While I could just connect a midi cable to the second output on the merger box and then connect to Midi In on the MMLT when I want to edit presets on the Timeline, it really slows the workflow. Plus, I am using the Midi in on the MMLT as a second midi out, which I have to say is just one of the brilliant features of the MMLT. It allows me to isolate a piece of midi gear that appears to add noise to the rig when connected serially, but behaves when isolated.
So, does midi forward not work when using a 7-pin cable for bidirectional communication? Is this why Nixie cannot connect to the Timeline via the 7-pin cable, but can connect when using two cables connected to midi in and out on the MMLT?
As always, thanks.
As always, thanks.
