I have a rjm multibox as the primary midi hub of my setup.
In/Out with Fractal FM3 and the 7 pin bidirectional MIDI to RJM GT16 (and power)
I have a few other midi devices using the TRS out and the standard MIDI thru goes to even more devices.
Everything works fine, but I've tried to incoprorate a midi controlled loop switcher and there is an audible tick, which is amplified when a loop is engaged.
https://drive.google.com/file/d/1f_KMju9ttXymQA1EGxQcuYwWjOnMP1am
it matches the flashing blue light on the multibox at the polling rate.
I've tried two different midi controlled switchers with the same results. I have tried different midi cables, using independent power supplies, etc. There is no remedy.
Is there anything else I can try? The only solution I've seen elsewhere is to use a midi merger that filters out active sensing from the midi messages but I was hoping for space, power and financial reasons to not have to buy another piece of kit. Is there a different jumper set up I could potentially try with the multibox? Anything else?
