UPDATE: This is just a note to say that you were absolutely correct the problem I was having with bidirectional midi and the Axe-FX II XL+ was the midi cable. I thought I was using a 7-pin cable, but it was actually 5-pin to 7-pin. As soon as I replaced the cable with an 7-pin to 7-pin cable, I was able to get bidirectional communication working. I now have the tuner and tap tempo and only one cable from the AXFX to the mastermind LT. Just thought I would let you know that you nailed. User error.
Hi,
I followed the direction to get the Axe-Fx tuner to display on the Mastermind LT: IA button assigned CC action tuner on Axe-FX; System/Tuner added as second action; update on preset change checked; and bidirectional midi checked.
When I press the IA button, the tuner turns on on the Axe-Fx and I see >?< on the Mastermind screen. Plucking a string displays on the Axe-Fx, but the Mastermind LT does not change from >?<. What am I doing wrong?
Hi,
