Bank up / bank down issue
chemh0ser
I am having an issue on my GT22 where the bank up and down buttons do not work. When I press either one, the screen briefly flashes to the next bank but then reverts to the same bank I was in not allowing bank up or down. The odd thing is, if I go into settings and calibrate my expression pedal, all of a sudden, the bank buttons work. Any idea what could be causing the issue?
Do you have any actions defined on the expression pedal? And, are your bank buttons normal buttons, or external switches?
I have the mission control rjm expression pedal. I just have it set up as an external controller for my axe fix III. I do have the switch on the pedal set up to switch the Volume block off and the way block on.
Page Preview is probably the culprit, it might be interacting with the Axe-Fx III Poll State. Try turning it off and see what happens.
I have had the same problem lately but thought my switches might be going bad. I’ll try the fix next time I play.
