Hi. First post on this forum, and I’m not sure I’m in the right place…
I just picked up a Goldfinger 90 without a footswitch. Does RJM make an adapter I can use that I can interface a 5 button midi switch with to control the amp?
Unfortunately we don't make that kind of thing anymore. In general, you'll need something to translate MIDI commands to footswitch operations, then you would need a cable to adapt to the specific connector your amp has. If you can find one of our Mini Amp Gizmos online, Best-tronics (www.btpa.com) would be able to make the interface cable needed. Or, you could probably do it with a Voodoo Lab Control Switcher and a custom cable, that Best-tronics could also make.
