George
My Protein Dual OD showed up the other day, a very nice Overdrive box. It came with instructions which made mention of using of a TRS plug which I only glanced at. Subsequently while watching some review and demonstration vids (Andertons Music on Youtube was did an overview of about 4 OD pedals) one of the hosts made mention of the Protein's TRS feature but said "you can use an insert cable...and blah blah blah..." Didn't seem to me that the instruction card made any mention of an insert cable...so I went back and this is what it said...
That seems to say that a TRS cable plugged into what I assume is one of the stereo capable inputs of the PBC/6X from each of the two pedal connections sides can have its own loop...Are they talking about an Insert cable? I'm baffled, any clarification much appreciated.
Keoki
Protein Dual Overdrive
“To use with a loop switcher like the RJM Mastermind etc. - The TRS plug on the input is going to act as the loop for the Green side. The TRS plug on the output is going to act as the loop for the Blue side. Tip is the input/send from your loop. Ring is the output/return to your loop. There are two DIP switches inside the pedal that need to be flipped down to the “split” position to use it this way. Remove the four access screws from the back panel and flip the switches to the down position.”
Keoki
