Thanks! My stereo/mono switch was not set correctly - problem fixed!If you lose signal when the buffer is disabled, you have a cabling issue. Either you have a cable with a short in it, you're using the wrong kind of cable(s), or the stereo/mono switches are not set correctly. See this post for details - if you're using any stereo pedals, you have to be very careful with the cables you use:
