BUG: IA > System > PC
Alexander
I've assign "IA > System > PC 384" to a button's HOLD function, to quick-jump to my main Axe-Fx III preset, which #384.
During a session, there's often a point where this HOLD function won't take me to preset 384 anymore, but to a preset in the first bank (from memory: 128). I haven't been able to find the exact cause. Maybe it messes up the Bank Select message.
It's a System / Preset preset:384 action, correct? PC actions can only specify up to 128.
But yes, I suspect that this is a bank select issue.
Turning on Send Redundant PCs for the Axe-Fx's device entry might help if it's not already on.
You could try doing something a little unorthodox and add preset actions to your preset:
Axe-Fx / CC Toggle #0 pff:None on:2
Axe-Fx / PC off:None on:127
Basically forcing it to select the bank and preset again, which may work around the problem.
Yes, you're right, it's "Preset", not "PC".
"Send Redundant PCs" was alreadyturned on.
The commands above do not work for unknown reason.
But I've added the "CC Toggle command" ("on:3") in front of the Preset command, and I'll see how it works out.
Thanks
Correction:
Axe-Fx / CC Toggle #0 off:None on:3
Axe-Fx / PC off:None on:0
These commands do work (The GT's main display updates a little slow).
