HI! I own a GT22 ! and I want to control de Diezel Hagen MIDI Amp for changing the Channels (1-4).
MIDI Functions Available:
https://www.diezelamplification.com/hagen/
MIDI / MIDI allows for any of the 4 independent channels to be fully programmable and switchable with a midi foot controller. This gives you access to each channel with the capability to add any desired FX. Programmable MIDI makes switching amp channels with different FX combinations instant.
Instructions at the manual
https://www.diezelamplification.com/manuals/en/Hagen_Manual_24102016.pdf
7.4.2 Single Channel Mode – Automatic Channel Recognition Your Hagen can automatically recognize the pedal’s send/receive channel. To get your amp into the mood (or mode) for this, push and hold “Mute” and then activate any program change button on your MIDI pedal. The amp will look for a program change and recognize the channel it is being sent on. Then it will switch to this channel and stay there as soon as you let go of “Mute”.
Any experience with this? Works fine? Any recommendation?
Thanks!!!
Xavier
Thanks!!!
Xavier
