Phisherman
On the 12 loop Effect gizmo, due to position, I’m curious if any of the effects in loops 1-8 are hitting the tuner out signal or if that’s clipped to the input jack and bypasses all of the loops?
Great! Thank you.The tuner output is just a secondary output from the buffer, so it splits before all of your loops (unless you patch the buffer in later in the signal path).
Maximum 550mA, but that's with every loop turned on. Each loop, when turned on, draws around 34mA.Great! Thank you.
One last question. The back of the EG on the power it says 9VAC or 12VDC. If it’s ran @12VDC how many mA does it draw?
