Expression pedal LED light
spikeymcspikeface
Hi - a tiny little issue ...
I'm using a Mission RJM SP-1 plugged into a GT-16. I've set the toe-down function switch on the SP-1 to activate a loop on my MEGX and switch on a rack wah (ProStage WahryTone). It's all working perfectly, apart from one tiny little thing: the LED on the expression pedal stays on irrespective of the status of the function switch.
It'd be great if I could set the LED to be off when the wah is off and on when the wah is on - for obvious reasons. I had kinda assumed this was possible, but can't seem to find any way of making it happen.
Am I barking mad, or should this be possible - and if so, how ...?
Thanks.
Make sure that the external switch's Off Color parameter is set to black, and the On Color is set to something other than black. External switches interpret black as meaning "LED off" and any other color as "LED on"
