Ext Sw Programming
Robert Payne
Hi, I'm having trouble programming the Ext SW in the editor. Basically I need an external Tap Tempo assigned to CC62 on Channel 1 and 2 and CC 20 on OMNI (any channel will work).
I'm using the MXR Tap pedal with a TRS.
Can you help me?
Tap tempo support varies from device to device, manufacturers don't seem to agree on how it should work. But, the attached settings should at least get you close. The fact that you are controlling at least two different types of devices, and the fact that one is running in omni could cause problems. But, let's see how far this gets you.
