Feature Request: Cycling CC numbers
tandrewnichols
I think it would be handy if, like with PC numbers, you could cycle CC numbers for parameters that have a finite number of values (but more than 4 where IA Cycle would do the trick). Like cycling through the Timeline delay engines for example. Those are CC# 19 with values 0 to 11. If you tried to do with IA Cycle . . . you could do it by using 4 buttons with 3 settings each, plus an empty slot, and using Set IA to set the other buttons to empty, but that's pretty tedious.
