FM3 with LT Preset increment / decrement
toneseeker911
I am trying to change presets on the FM3 using a mastermind LT. For some reason, when I press an increment or decrement button, I can see the LT momentarily changes to the new preset, but then goes to a multiple of 128.
Eg, if I was at 128 and did Preset decrement, the LT flashes 127 for a brief time then switches to 0 (The FM3 also switches to 0). And this wraps around at 384.
Here is my settings file, if that helps
  • oct_22_2025.rjs
Thanks for the suggestion. But that only made the LT switch correctly. On the FM3, it still moves by 128 and the preset on the FM3 gets out of sync with the LT.
I also tried disconnecting the cable from FM3 -> LT . So just one way. And it is a similar behavior.
I don't need to use Preset+ or Preset- . Is there a way to send PC and CC (as an IA maybe) to achieve this as a workaround ?
When I used Device PC+ or Device PC- after Ignoring incoming PC, it changed the preset on the FM3 normally. But the LT is not in sync.
For now, I turned off "Ignore incoming PC" , turned off "Send redundant PC" . This way, I am at least able to change presets on the FM3 using its onboard switches and it reflects on the LT. Not ideal. If you have another solution or want me to try anything else, please let me know.
Your Get Preset Names button has a PC action on it that will trigger every time you change presets. Remove that action, it's guaranteed to cause problems. Also the IA1-IA4 buttons on page 2 are set to send their messages on each preset change. They might cause trouble, they might not. But, unless you have them there for a specific reason, I recommend removing them, or at least turning off Send on Preset Change on them.
That was it, thank you! I don’t remember setting any of those, I just chose the button type. I went and cleaned up all the buttons and everything works great.
