ataglianetti
I'm wondering if I'm doing something wrong or if there's a bug with this feature.
I'm using Native Instruments Machine to send MIDI clock to the PBC 6X (FW 4.5.0). If I set the PBC 6X to Slave, everything works as expected (though it doesn't display the incoming Tempo from Maschine). If Maschine is stopped, or not open, I cannot use the PBC 6X Tap Tempo to generate MIDI Clock.
If I set the PBC 6X to Master, it generates it's own clock, set by a Tap Tempo button I have setup, but it ignores MIDI clock sent to it's USB port.
What I would like to do, is have the PBC 6X slave to MIDI clock over USB when it's available, but also be able to generate it's own clock via Tap Tempo when it's not. That's what I assumed the MIDI Clock Auto setting was for, but it's not working as expected.
I generally run my pedal board in two ways
- Mono, 4CM with my amp, no computer / external MIDI Clock
- Stereo, into my audio interface, DAW sending MIDI Clock
