Hi
The presets work fine but the IA buttons that are assigned to the loops in the MEGX are not turning on and off the loops. I'm sure this is a two click fix but I'm stumped. Thanks in advance!
The first things that come to mind are:
- Check the channel setting for the MEGX (on both the device and in the GT editor)
- Try a different cable
- Try connecting the MEGX directly to the GT if it isn't already, in case a device in between is causing problems
