Hi,
I just wanted to pass along some information, in case it might be helpful to other users. I have a Timefactor and Modfactor. I am using an RJM Mastermind for midi control. I have been trying to assign to the CC assigned to the expression pedal to control a function in the Timefactor. I had been using an Ernie Ball volume pedal and an M-audio expression pedal into the Mastermind. With both pedals, I had problems with the Timefactor. For example, when I assign the CC assigned to the pedal in the Mastermind to the Mix knob on the Timefactor, the pedal did not sweep evenly from 0 to 127. I tried numerous times to calibrate the pedal (and yes, I had the polarity correctly set according to the manual), but it always just sweeped erratically through the range. I finally tried a Yamaha FC7. This is a winning combination. Now the sweep from 0 to 127 is even.
So, if you have an RJM Mastermind and a Timefactor, and you are having trouble with other expression/volume pedals, try the Yamaha FC7.
All the best,
All the best,
