Hi,
here is my issue.
My Fractal Axe FX 2 XL + is on Midi channel 5 controlled by my mastermind GT16 with a 7pin midi cable and the phantom power box.
I want to send Midi messages from a external device to control the fractal.
So I connect the MIDI OUT from my external device to the REMOTE IN from the mastermind GT to send the Midi messages on channel 5 to control the Fractal.
I've fiddled around with the MIDI settings on the mastermind GT but can't seem to find the right approach.
I know Mastermind is set on Channel 1. If I turn it to channel 5 of course the mastermind goes nuts.
So what should I do ?
I tried the MERGE OPTION but it goes nuts (flashing and changing settings randomly)
What would be the best approach to send my midi messages (Program changes, scene changes and some looper RECORD/PLAY messages) ?
Or should I use only Midi message to control the mastermind GT instead of trying to control the Axe FX directly ?
if that's the case what would be the midi message to send to the Mastermind GT so it can control the presets, scenes and looper function ? I'm a bit confused with the midi implementation chart in the user manual.
Your help would be, once again, highly appreciated. I'm stuck and can't seem to find the solution.
(note : when I'm sending my Midi Message via USB directly on the Fractal everything works perfectly so it's just a matter of turning the REMOTE IN into Merger or just a pass through ? )
>>>Update<<<
I've put the Mastermind GT on Channel 7 and could find the Program Change command to change the presets. It's working. But I can't find the right CC message to control SCENE changes, Looper function and individual effects ON/OFF etc. The chart n the user manual doesn't really explain it to me (or at least I don't get it )
here is my issue.
>>>Update<<<
