At long last, here's a first look at Mastermind GT 3.0. The major features are:
- Expansion to 768 presets (keeping up with the Joneses, or in this case, the Fractals. )
- Page up and down buttons now can have limits set on them so they only scroll through a subset of active pages
- Device PC - and PC + buttons allow you to scroll through presets on a specific device without affecting other devices
- "Start on last preset" setting makes the GT start up on the last preset that was selected before it powered down
- Display brightness and contrast are no longer part of each GT's settings file, so transferring settings between GTs doesn't screw up your contrast settings
- "CC Link" on IA buttons allows for control of IAs from incoming CC messages (from a computer or other MIDI controller)
- And some bug fixes of course
This is a beta release, so expect bugs! Don't install this right before your big tour. Please PM me or post your comments here if you find anything weird in this release.
UPDATE 8/5/2015
3.0 beta 2 is now available, which now includes:
- Song-level tempos. You can set a tempo for each song now. Preset tempos override song tempos, so be sure to set your preset tempos to 0 if you want the song tempo to operate correctly.
- Page names. You can now name each global and local button page. This name will show up when switching pages and in the page menu. There's also a setting in Display Settings that turns on the page name display in the top line of the main display.
- Reverse Menu settings. Turning this on (in Display Settings) flips the Page, Preset, Song and Setlist menus so that they start at the bottom row of the GT instead of the top.
- Added support for Mastermind PBC and Atomic Ampliifire (untested!)
- Updated support for Infinity Looper 2.0 firmware
- The vertical bar character '|' can be used in button names to add extra text to the button that is only displayed when editing the button. Anything after the bar will not be displayed in the button in normal use
- Bug fix: start on last preset doesn't work when setlist is set to All Songs
- Bug fix: a momentary button with a hold function didn't display correctly
- Bug fix: Copy and swap buttons on the GT itself didn't copy hold functions and cycle data
Update Instructions:
1). BACK UP YOUR SETTINGS!!! If you have to go back to 2.3.6 or 3.0b1, your GT will factory reset.
Note: the first time the GT boots up after the update, it will need to convert your settings to 3.0 format. It will take a few minutes to do this, so be patient and let it finish!
Here are the files:
Firmware: http://www.rjmmusic.com/downloads/MMGT30B2.zip
Manual: http://www.rjmmusic.com/manuals/Masterm ... al-3.0.pdf
Mac Editor: http://www.rjmmusic.com/software/MMGTEditor-3.0b2.dmg
PC Editor: http://www.rjmmusic.com/software/MMGTEditor-3.0b2.zip
UPDATE 8/5/2015
Here are the files:
