Firmware 3.2.3 is now available. It has some new device support, a few new features and the inevitable bug fixes.
Fixed a bug that screwed up number editing in the on-board setup menu
UPDATE 3.2.2 - 4/1/2016:
Fixed some bugs:
More bug fixes:
A small update (firmware only, no editor changes):
One bug fix:
1). BACK UP YOUR SETTINGS!!! If you have to go back to 3.0, your GT will factory reset.
2). Download and unzip the firmware file below, then copy it to a USB flash drive. Be sure to select the "Eject" option on your PC to make sure that the drive is in the right state before pulling it from your computer.
3). Power up the GT while holding the two black buttons under the screen. Wait until the "Mastermind GT Bootloader" screen shows up, then plug in the flash drive. It should run the update at that point, which takes less than a minute.
Note: the first time the GT boots up after the update, it will need to convert your settings to 3.1/3.2 format if you weren't already running 3.1. It will take a few minutes to do this, so be patient and let it finish!
Here are the files:
Firmware: http://www.rjmmusic.com/downloads/MMGT325.zip
Manual: http://www.rjmmusic.com/manuals/Masterm ... al-3.2.pdf (coming soon)
Mac Editor: http://www.rjmmusic.com/software/MMGTEditor-3.2.3.dmg
PC Editor: http://www.rjmmusic.com/software/MMGTEditor-3.2.3.zip
- Added support for Fractal AX8 and FX8
- Added minimum and maximum limits to preset and bank buttons. (Bank buttons only when in song mode). This allows you to set up buttons that only scroll through some of your presets, songs, etc. We had this ability for page up and down, but it's now extended to these other buttons.
- Added support for decimal tempos. You can now specify tempos with one decimal place (120.5, 60.2, etc.)
- Preset - and + buttons will now scroll to the next song once you've moved through all presets in a song
- A button that has a hold function will now repeat if held longer (and if it's a repeating function like bank up/down)
- The tuner can now be activated as part of a preset change
- Fixed a bug that caused trouble with Axe-Fx and Kemper IA button states
- Fixed a bug that affected bank select and "preset 2nd press"
- All IA buttons that have Send on Preset Change enabled will now send on startup
- Fixed a crash bug in the editor
Fixed some bugs:
- Fixed one that made the expression pedal position switch do weird things
- Prevented the tuner from showing up when it wasn't supposed to
- Tempo buttons can once again send MIDI messages
- Expression pedals no longer send values on startup unless the "send on preset change" checkbox is turned on
More bug fixes:
- External switch settings now save correctly when editing on the GT
- Fixed a hang that happened when transferring settings in MIDI Clock slave mode
- Added missing Y-Not CC definitions
- Editor: fixed drag and drop between internal and external buttons on the Buttons tab
- MIDI Clock master mode have been causing problems with the USB MIDI interface, breaking settings transfer in some cases. Tracking the source of this down has proved to be pretty challenging. For now, I have disabled MIDI clock output through the USB port. It will still send MIDI clock through the main MIDI output in master mode, and will still receive clock through the USB port in slave mode. if this change causes a problem for anyone, please let me know. I will revisit this problem to fix it for good, but how quickly I get to it depends on whether people are inconvenienced by the change.
- Fixed number of PCs and banks for Boss DD-500 (they were reversed)
One bug fix:
- Fixed external switch state handling - was not begin recalled correctly when switching presets
Here are the files:
