Hi, Ron -
All previously reported issues with 4.1.0 and the FXII-XL+ are cured with 4.2.0.
But then you already knew that, didn’t you? Of course you did...
One Million Thanks 2 U - again!
Bruce
Is there a way with 4.2.0 to send a #cc on Axe-FX midi channel from my iPad connect to the GT USB port, to recall a specific scene in the Axe-FX III?
Can I assign cc#34 in the Axe for scene control and play with the value to get the scene I want to recall? Will it not conflict with the sysex that are assigned in the GT OS? Can't test it right now, but will give it a try. Thanks a lot.If you turn on MIDI Merge in the GT, it will forward all MIDI messages from the iPad to the Axe-Fx.
Thanks Ron, it works. Marvelous! I have a preset that default to scene 1, I add in my iPad a cc#34 to get scene 4, the Axe goes to scene 4, but the GT stays on scene 1. Is there a solution for the GT to follow the scene in the Axe? I tried cc link in the IA's scene buttons with no success.
The goal is to have each song in my iPad send the correct PC, but also the right scene number, as I use the same preset in different songs with a different scene. The GT shows the selected Axe's scene on my Axe-Fx II. I hope this can be done in the III.
"Ignore Incoming CC" is turned off in Devices.
It is turned on, when I bypass a block in Axe~ Edit, it is well reflected on the GT. Scenes seem not to be updated.Make sure that Poll State is turned on in Devices.
This happened only when I reboot the Axe. And it does it only once, after that it continue to behave with the same error, right scene in the Axe, and wrong on the GT.My last post is important to get scene names right, but I've just realized that it won't help your situation. I will look into it further. If it's reporting the wrong scene after a few seconds, I suspect this is an Axe-Fx bug. We'll see...
