MASTERMIND GT FIRMWARE / EDITOR 4.5.0
Discussion in 'GT General Discussion' started by rjmmusic, Jun 27, 2020.
  1. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Another new release for you...
    FEATURES:
    • (UNTESTED) Support for Fractal Audio FM3 and Strymon Compadre. Please let me know how these work for you!
    • Dev PC -/+ and IA buttons that select presets on devices can now be linked together so that selecting one updates the other. Any time a PC or bank message is sent to a device - for any reason - the Dev PC buttons will update to reflect the new numbers. If an IA button has a CC0 or CC32 action followed by a PC action as the first two messages, or just a PC action as the first action, and IA Link is turned on, the IA button will respond to other IA buttons and the Dev PC -/+ buttons. For example, a button that sends PC 10 to a device will automatically turn on when PC 10 is sent to the device, even if it was sent by another button.
    • The MIDI Merge setting has been broken into In, Out and USB settings. You can use these to choose which ports are forwarded to the output, and which aren't. If you were merging from the In to the Out port, you will have to manually turn on the Merge: In setting after upgrading to this release. The Out setting is new and allows the input side of the bidirectional MIDI Out port to be forwarded out the MIDI Out port, which wasn't possible before.
    • When MIDI Receive Channel is set to something other than None, incoming CC119 messages on that channel will change the page number on the GT. CC 119, value 0 will select page 1, CC 119 value will select page 2, etc. This CC number is not user configurable yet, but will be in a later release.
    • Axe-Fx channel select menu now highlights the currently active channel name.
    BUG FIXES:
    • Fixed editor drag-to-swap feature - it didn't work correctly when dragging to external switches
    • Fixed some CC values for Strymon pedals
    • Fixed special characters in preset, song and setlist names - for example, you can put a '\' character in a song name to force a line break (primarily useful if you have "Show Song Name Only" turned on)
    • Fixed scrolling of file names when loading settings or selecting a firmware file to upgrade - you can now select from a list that's longer than the screen can display all at the same time.
    TO UPDATE FIRMWARE:
    - First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your GT will factory reset.
    Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT450.zip
    Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.5.0.dmg
    PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.5.0.zip
    Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf (update coming soon)
    Editor Manual (not updated for 4.4 yet): http://www.rjmmusic.com/wiki
    Paggzy, Jop, Alexander and 2 others like this.
  2. Rain
    Rain
    Apr 16, 2013
    178
    15
    Awesome Ron thanks!!!! I’ll test it tomorrow with my FM3 and Keep you posted ....!!
    #2 Rain, Jun 27, 2020
  3. Chuk
    Chuk
    Aug 19, 2018
    26
    9
    Thanks Ron.
  4. touch33
    touch33
    Oct 15, 2017
    46
    10
    Rob —
    Absolutely LOVE the AFX3 “channel” indicator using text reversal! Simpler/slicker than my “color highlight” idea, works superbly, and maintains the existing GT “function style”.
    Thank you, Sir!
    Bruce
    Alexander likes this.
  5. Neill00
    Neill00
    Jun 1, 2020
    37
    6
    This is great. Being able to choose pages via midi solves everything for me.
    Paggzy likes this.
  6. Dwelltone
    Dwelltone
    May 25, 2019
    17
    2
    I'm still having the issue where the default scene (1) is not showing on when changing presets on my III. Is there something I can change settings on to get that back?
  7. Alexander
    Alexander
    Oct 21, 2014
    476
    165
    This doesn't seem to work yet for each block. E.g., it doesn't work with my Drive 2 and Drive 3 blocks.
    @rjmmusic
    #7 Alexander, Jun 29, 2020
  8. Alexander
    Alexander
    Oct 21, 2014
    476
    165
    So far, this release seems to have fixed the bugs that I know of.
    #8 Alexander, Jun 30, 2020
  9. Alexander
    Alexander
    Oct 21, 2014
    476
    165
    Also, the FM3 implementation seems fine!
    I just changed the device in my configuration from Axe-Fx III to FM3, and everything works, without further adjustments. Including getting preset (and scene) names, update preset name, engaging/bypassing blocks, switching channels.
    To make connected pedals and switches, I had to adjust some FM3 MIDI/Remote settings, of course.
    Wonderful.
  10. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Interesting... I'm working with someone who says that he's not getting effect block status updates from the FM3, but communication works in the GT->FM3 direction and tap/tuner are ok. That's all working for you? Does Poll State seem to track all changes made on the FM3 or editor?
  11. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Glad to hear it! I'll look into the Drive 2 / Drive 3 channel selection issue.
  12. Alexander
    Alexander
    Oct 21, 2014
    476
    165
    Stupid me, I tested only GT > FM3 traffic.
    I tested again and indeed, the GT does NOT show effect block updates (on preset switching nor bypassing single blocks). The GT does follow preset switching on the FM3 (without the block updates). So it seems related to CCs.
    I only used the FM3 hardware, not the editor.
    I'll inform Fractal's developers.
    Rain likes this.
  13. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Ok, thanks, I have an FM3 on the way as well. With their help, we should be able to resolve it.
    Rain and Alexander like this.
  14. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    I have an FM3 here now, and it appears to be a bug in the FM3. I've contacted Cliff about it.
    Alexander, Rain and iaresee like this.
  15. Rain
    Rain
    Apr 16, 2013
    178
    15
    Awesome !! Thanks Ron !!!
Share This Page
