Firmware and editor version 5.3.1 are now available!
FEATURES:
You can also read the full change log if you like.
UPDATE 12/17/2024, Version 5.3.1
Version 5.3.1 adds support for the following devices:
- Power on the Mastermind while holding the two small buttons under the main screen.
-OR-
- Use the editor's Transfer / Update Firmware menu option to update the Mastermind. This works with Mastermind GTs made after March 2019.
Firmware: https://www.rjmmusic.com/download-content/MMGT/MMGT531.zip
Mac Editor: https://www.rjmmusic.com/download-content/MMGT/MMGTEditor-5.3.1.dmg
PC Editor: https://www.rjmmusic.com/download-content/MMGT/MMGTEditor-5.3.1.zip
Manual: https://www.rjmmusic.com/download-content/MMGT/Mastermind GT Manual-4.3.pdf
FEATURES:
- New device support:
- Chase Bliss Mood mk II (fixed previous attempt) and Onward
- GFI Duophony
- Morningstar ML10X
- Strymon Big Sky MX
- Quad Cortex: Added individual scene CCs (Scene A, Scene B, etc.)
- Kemper: Added looper buttons (for real this time, had some wires crossed last release...)
- All devices can now be set to respond to incoming PCs. For example, let's say you have a device on channel 5. If Ignore Incoming PCs is turned off, incoming PCs on channel 5 will cause preset changes on the GT. And, specifically, an incoming PC on channel 5 will never result in the Mastermind sending a PC on channel 5. This prevents MIDI PC feedback loops.
- The above feature is probably not needed or desired in most cases. As a result, Ignore Incoming PC and Ignore Incoming CC are now the default setting for most devices.
- The Set Preset PCs to 0 and Set Preset PCs Sequential buttons in the editor now ask for a preset and bank number. This will set all preset PCs for a device to a specific bank and preset (in the case of the Set Preset PCs to Value button) or it will assign sequential PCs starting at the given PC and bank (in the case of Set Preset PCs to Sequential)
- It's once again possible to recall presets that are not in the active setlist.
- Fixed an issue that could cause buttons to incorrectly send their messages more than once when using Set IA.
- Fixed expression pedal issues when in Remote Mode.
- Fixed a bug that caused the previous screen to stick around after cancelling a Preset Number menu.
- Fixed an issue that caused tempo to continue to be displayed on buttons when MIDI clock is turned off.
- Added the missing Alt Preset Color setting in the editor
- Fixed numerical editing (like BPMs) on Mastermind GT/10
- It's now possible to show both preset numbers and scene names at the same time on the main screen
- Fixed an issue where drag and drop in the editor, followed by Send Changes To Device, didn't result in all data being updated correctly.
- BluGuitar Amp1
- Chase Bliss Clean, Habit and Lossy
- Diezel VH-X
- EHX POG3
- Friedman IR-C, IR-J, IR-X
- GFI Enieqma, Solus Ventis
- Kemper Player (still needs a USB host adapter to connect)
- Radial Engineering JX-44 v2
- Two Notes Opus
- Walrus Meraki
- BPM changes made using System / BPM actions can now be stored using IA Store buttons and actions
- IA Cycle menus now highlight the active option no matter which row the buttons are in
-OR-
