MASTERMIND LT 5.0.1 FIRMWARE / EDITOR
rjmmusic
Administrator
Staff member
UPDATE 3/22/2023: 5.0.1 has been released, details below
I've just uploaded version 5.0. This sounds like a big deal, but it's actually a minor release. I ran out of single digit minor release numbers, so I had to move up to 5.0.0 to keep my numbering scheme intact. Sorry for any disappointment for anyone looking for major improvements!
FEATURES:
  • New device support:
    • Eventide H90
    • Jet Lamb, Lion and Revelation
    • Kernom Ridge
    • Meris LVX
  • Added Wrap Banks setting which, when enabled, allows Bank Up / Bank Down to wrap around from the first bank or song to the last bank or song. (Or vice-versa). Keeping this setting turned off works as it did in the past, where you can't Bank Up past the last bank/song or Bank Down past the first bank/song.
  • Changed how special text is appended to buttons (PC number in Device PC -/+ buttons, effect block types in Kemper, etc.) Now, special text is given priority so that it can't get cut off if your button name is too long.
  • Fixed a bug that caused IA Cycle buttons with CC Momentary actions to malfunction
  • Added some sanity checking and protection code to MIDI bank handling
CHANGES IN 5.0.1:
  • Fixed the CC list for Eventide H90
  • Fixed default tap tempo CCs for some Strymon pedals
  • Enabled scrolling with up/down arrows in the Mastermind editor song and setlist lists
  • Extra data (device PC info, KPA effect names) is now stripped from button names before transferring to the editor
  • IA Store now stores tempo correctly in the current song or preset based on the current settings
  • Show Tempo no longer interferes with bank selection
  • Fixed some weird interactions between bank selection, alternate presets and page changes
TO UPDATE FIRMWARE:
-OR-
- Use the Transfer / Update Firmware menu option to update the Mastermind. This works with the LTs made after March 2019.
Firmware: https://www.rjmmusic.com/downloads/PBC/MM501.zip
Mac Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.0.1.dmg
PC Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-5.0.1.zip
Manual: https://www.rjmmusic.com/downloads/MMLT/Mastermind LT Manual-4.2.pdf
Thanks alot!
Looks like this Mac version won't work with Mac OS Sierra 10.12.6 btw.
But I'll try with my Windows laptop and see.
