Here's a new firmware release for you to try. The headline feature is for the Mastermind PBC/6X, but there are some things for the LT as well.
TO UPDATE FIRMWARE:
- First, back up your settings to a flash drive or computer! If you go back to 4.1 or earlier, your Mastermind will factory reset.
Firmware: http://www.rjmmusic.com/downloads/PBC/MM432.zip
Mac Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.3.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.3.0.zip
Manual: http://www.rjmmusic.com/downloads/MMLT/Mastermind LT Manual-4.2.pdf (same as 4.2 manual)
Editor Manual: http://www.rjmmusic.com/wiki (not yet updated for 4.3)
- Added (untested) support for GFI Specular Tempus and Cabzeus
- Implemented the Get Preset Names button type (for use with Axe-Fx/Kemper)
- Fixed a bug that prevented editing of scene numbers on the PBC/LT
- Fixed a bug that caused weird behavior after changing a button to or from the Preset type
- Fixed preset name editing
- Fixed Assign CC > Internal editor menu for all models
TO UPDATE FIRMWARE:
