Mastermind LT / Firmware Release 5.4.0
Firmware and editor version 5.4.0 are now available!
FEATURES:
  • New device support:
  • Fractal VP4 is supported as a normal (non-bidrectional) device for now. We need to work some more things out with Fractal before we can have full support
  • New setting for groups: "Allow multiple on". As the name suggests, turning this on allows more than one button to be on in a group. This is for certain special cases, like when you have more than one MIDI controlled pedal in a switcher loop. You can set up a group action with this setting to turn off the loop when all pedals in the group are off, and turn the loop on when one or more pedals are turned on.
BUG FIXES:
  • Fixed some problems with expression pedal switch actions
  • Improved message handling of Axe-Fx communication
  • Fixed a lockup on startup that happened on rare occasions
  • Fixed bank selection - preset on/off colors are now displayed properly
You can also read the full change log if you like.
TO UPDATE FIRMWARE:
-OR-
- Use the editor's Transfer / Update Firmware menu option to update the Mastermind. This works with the LTs made after March 2019.
Firmware: https://www.rjmmusic.com/download-content/PBC/MM540.zip
Mac Editor: https://www.rjmmusic.com/download-content/PBC/MastermindEditor-5.4.0.dmg
PC Editor: https://www.rjmmusic.com/download-content/PBC/MastermindEditor-5.4.0.zip
Manual: https://www.rjmmusic.com/downloads/MMLT/Mastermind LT Manual-4.2.pdf
