Ron,
were you ever able to figure what was going on here and correct it on the official 3.0 release? I doesn't seem to have corrected for me....
That should be fixed in the final 3.0. Please send me your settings if it's not working.
Ron,
emailed you!That should be fixed in the final 3.0. Please send me your settings if it's not working.
How stable is this release?
The thing is, I finally got to rewire my board for the PBC last weekend and updated the software to 3.0 and I have no experience with the previous software versions. I use the PBC with 2 external switches and an expression pedal.
My issue is this:
- The PBC sometimes does not recognise the external switches and expression pedal. Powering the PBC off and on again fixes this issue.
I need a solid setup by Friday. If that means switching to the previous software version and remaking all my presets in the previous editor, so be it.
By the way, except for this, I am really loving my new setup!
Are you using the tuner, then exiting the tuner by using a preset button? I'm wondering if you're seeing the same issue that Charlie is in the message above.
Ah, and one tiny remark:
Yes, that seems very likely: it happened when I was testing presets and I was using the tuner/mute a lot when adjusting stuff and I have the habit to go out of mute by switching to a preset...
I 'll see if I can recreate the issue this evening.
I have similar problem sometimes , sometimes PBC just freezz on a preset , unplug and plugin back fix problemHey Ron, I believe 3.0.1 did I not fix this issue successfully.
- Fixed a bug that made the Mute function not turn off correctly if you switched presets when in Mute mode.
