What's new about this model?
The big new feature is the ability to rearrange loop order. Your effects can automatically be placed in a different order for each preset. Aside from that, it's smaller and less expensive than the original Mastermind PBC, making it more suitable for smaller pedalboards.
What are its main tech specs?
The "X" indicates that this is a matrix switcher, which means that you can change the order of loops. We wanted to differentiate the PBC/6X from the PBC/10, which is a relay switcher.
Is the PBC/10 going to be discontinued?
No, we're selling both PBC models.
Will there be a PBC/10X?
We haven't decided that yet. We'd love to hear your opinion on this!
Can I upgrade my original PBC to have loop reordering?
Sorry, no, that would require a complete redesign.
Why would I want the PBC/6X over the PBC/10?
Why is there no line mixer / parallel capability in the PBC/6X?
The primary goal was to have a smaller, less expensive PBC. Adding an internal line mixer would interfere with both of those goals. You can use our Mini Line Mixer in conjunction with the PBC/6X to get up to three loops in parallel. You won't be able to switch between series and parallel on the fly - you'll get full time parallel routing for the loops connected to the mixer.
What are the dimensions and weight of the PBC/6X?
Dimensions: 10.1 x 4.4 x 2.4 inches (25.7 x 11.1 x 6.1 cm)
Weight: 2 lb (0.9 kg)
When will it be available?
We're hoping to be shipping by the end of March. We will likely be taking preorders in February.
What will it cost?
The projected cost (barring any surprises from manufacturing) is US$699. We will offer a discount to those who preorder. More details on that in the coming weeks.
Is this switcher true bypass?
Yes, it is, although it does it using different hardware than our other switchers. It uses an analog switch matrix chip, which means that the true bypass feature is implemented using transistors instead of relays. When a loop is switched off, it truly is out of the signal path.
Does this switcher convert my signal to digital?
The signal path is never converted to digital. The internal tuner uses a digitized signal, but that signal is split off from the buffer before being digitized and that digitized signal never makes it back to the signal path.
- 6 audio loops
- 1 insert loop, which can be used for a 7th effect, a split point for the 4 cable method or other special routing arrangements
- 3 loops and the insert loop are switchable between mono and stereo
- Programmable loop order per preset
- 1 switchable buffer at the input, and 1 buffer in the insert loop
- Secondary, switchable unbuffered input
- Expression pedal input
- External switch input accepts 1 or 2 button switch
- Function switch output which can control channel switching on some amps, or additional feature switching on select pedals
- MIDI output jack, which can be split into an input and output using a Y cable
- USB connector for connection to a computer to use with our Mastermind Editor or DAW software
- Easy to read LCD screen displays preset and song names
- Built-in tuner
- Fully user configurable using the Mastermind Editor software
- Extensive MIDI support (the same as our other Masterminds)
- Built in support for many popular MIDI devices
- The PBC/6X is smaller, which allows it to fit on smaller pedalboards (or allows you to put more pedals on a big board!)
- The PBC/6X is less expensive
- The PBC/6X has the ability to change its loop order on the fly
- The PBC/10 has more: 10 audio loops (4 stereo), 2 insert points, 3 buffers, 4 function switches, 11 buttons
- The PBC/10 has an internal line mixer that allows you to use parallel effect routing
- The PBC/10 has individual left and right outputs, and the right output has an isolation transformer and phase switch
- The PBC/10's layout has more space in between buttons and a larger LCD
- The PBC/10 uses relay switching which allows you to use it without any buffers. Matrix switching needs a buffer in front of it when used with a standard guitar
What will it cost?
